Burglar proof tractor
Bill from WI
11-29-2000 09:20:04
I am hoping you can help me. I will be leaving my C in a storage shed and would like it to stay there. I use it for plowing in winter. Does anyone have a good way of putting in a hidden kill switch or something like that. I would rather not put in a key switch (the only thing I do with keys is lose them ).
Thanks for any suggestions
Bill
'Bandit'
12-10-2000 19:17:39
 Re: Burglar proof tractor in reply to Bill from WI, 11-29-2000 09:20:04
Excuse the name...
But you might take one of the front tires with you. or take a rear one off, and hide the bolts. Just so you can recal where you left them when you return...
Tom
11-29-2000 17:32:32
If you are leaving it for a while, how about taking the starter, distributor, or some other such vital thng with you. If leaving it for a shorter time, take the rotor, or hide it. Switch the plug wires so it won't run, just remember no. one on the dist. cap and the firing order and you can easily fix it. Put a plug in a section of neoprene fuel line. Just switch it for a unpluged fuel line when you want to go.
kevin
11-29-2000 17:08:22
I have been known to take the rotor out of the distributor. Not too many thieves carry distributor parts with them or mess with something that won't start easily. In a pinch, take the battery too. I always thought kill switches were too easy to find.
Darrell (MN)
11-29-2000 13:47:21
Bill, we put a battery disconnect on our 190XT. You might be able to put something similar in the toolbox under the gas tank. We bought ours at a RV center, but you might be able to get one at a parts store. Good luck, Darrell(MN)
Rob in MO
11-30-2000 16:05:44
 Re: Re: Burglar proof tractor in reply to Darrell (MN), 11-29-2000 13:47:21
Those won't keep someone from winching on to a rollback truck. Around here, that's what they do. Someone managed to gank a BIG Deere dozer/loader in broad daylight last Spring from a site just off the highway. Improvise and make it very hard to roll away from the shed, and make sure no one sees you leave it there! Good luck, RC
