Wd45 hydrolics
Dave
11-28-2000 20:22:40
Just purchased wd45. The hydrolics don't work. I am not familiar with this tractor. Can anyone tell me where to start trouble shooting. Any help would be greatly appreciated.
Rick Roper
11-30-2000 08:30:43
 Re: wd45 hydrolics in reply to Dave, 11-28-2000 20:22:40
Did you ever figure out your hydrualic problem? I have a '55 WD45 and the 3-point will not pick up any weight. It will run up and down without weight on it however. I think the problem is in the hydrualic pump. What did you do with yours?
Thanks.
David Thomas
11-30-2000 12:44:49
 Re: Re: wd45 hydrolics in reply to Rick Roper, 11-30-2000 08:30:43
Rick,
Check out my response to Dave's second post. My WD45 is also a '55 ;-) with the same symptoms you mentioned. I think its due to a weak spring in the pressure relief valve (called an unloading valve in the manuals). I've added shims to the valve spring to bring the pressure up but its a trial and error method. I still have to put the thing back on the tractor to see where I'm at now. It will be awhile before I can do that as I'm into the front of the tractor now, replacing belts, hoses, thermostat, manifold gaskets, pulley bearings, etc. Long overdue maintainance but not a complete overhaul. (I flipped when I saw you gotta take the radiator off to change the belts!)
David
