Oil pressure
Bart lansink
11-27-2000 04:03:45
Hi there,
We just bought an allis c from 1948. It runs fine but the oil pressure is kind of low( approx. 10 psi warm and cold). What is the correct pressure for an engine that is in good condition?
thank you!!
Dick L
11-27-2000 16:37:39
 Re: oil pressure in reply to Bart lansink, 11-27-2000 04:03:45
The oil pressure is fine. These engines can operate on the lower oil pressures because the oil is not forced through the crank to the rod bearings and the crank runs at low RPM's. The rods gets it's oil from oil spraying from small holes in the cam onto the rods and running into holes in the tops of the rods where the caps bolt on.
Brian G.
11-27-2000 05:17:22
Normal oil pressure for a WD is 12 lbs. when hot and at operating speed. I would guess it should be about the same for your "C".
Fred
11-27-2000 05:50:42
 Re: Re: oil pressure in reply to Brian G., 11-27-2000 05:17:22
I have the original 1942 manuals with my C and believe it or not the manual says the oil pressure needle should read between the R and M in normal, they were real technical in 42. Good luck
Tom
11-28-2000 17:37:24
 Re: Re: Re: oil pressure in reply to Fred, 11-27-2000 05:50:42
I have seen a B run for hundreds of hours with little to no oil pressure. As these engines wear they loose oil pressure, but they still have oil flow to the bearings. Ten pounds sounds fine to me, especially if it is with hot oil.
