Thanks for Magneto help, but...
cm
11-25-2000 20:38:01
Thanks Dick L. for the blow up of the magneto. There are a few things I still would like to know before blowing up my magneto.
The magneto # FMJ4B3. The local Napa does not carry a replacement coil. Can anyone recommend a supplier? Is there anything I should do or look out for before, durring or after installing the new coil?
Thank you
CM
Dick L
11-27-2000 17:06:29
 Re: Thanks for Magneto help, but... in reply to cm, 11-25-2000 20:38:01
C M, I have bought several mags real cheap because the coils were supposed to be bad. I have found the coils to be good and the problems to be with the points or the impluse. You can check coils with an ohm meter with out removeing it from the mag.
You can clamp the mag in a vice and check for spark at the points with a screw driver from the case to the points while snaping over the impulse, without a meter.
