Dads 34 WC Front Pulley on motor wobbles
Tom
11-25-2000 09:50:06
The fan pulley on crankshaft wobbles a lot, also this tractor goes what seems to be really fast for first gear, is all steel #409 looks and runs great. appreciate your help , Tom
Tom
11-25-2000 14:20:05
 Re: Dads 34 WC Front Pulley on motor wobbles in reply to Tom, 11-25-2000 09:50:06
My brother has a WC that had this problem when he got it. He ended up taking the crankshaft out of it and turning the end down, pressing on a bushing, turning this down to the original diameter of the crank snout, boring the pulley and bushing that, all to repair a loose and worn pulley like what you describe. The one big set scew loosens up and the pulley destroys itself and the front of the crandshaft.
This problem could happen to any of the W series engines, and any others I suppose with this method of securing the pulley to the crank snout.
Good luck, it isn't as bad as it seems at first.
Tom
