Tips on removing old temp gage.
CM
11-23-2000 09:19:46
I am looking for any tips for removing an old temperature gage from my WD. I have a replacement but the old one doesn't want to budge and I would really hate to twist the top half of my radiator off. Thanks
Happy Thanksgiving.
CM
charlie
11-30-2000 20:01:30
 Re: Tips on removing old temp gage. in reply to CM, 11-23-2000 09:19:46
I had the same problem with mine, took it to a radiator shop. He couldn't get it out... sent it to a machinist. Total cost.... $25.00! cheap at half the price... BUT...It is like heck to get the radiator off!
TexasRed
11-25-2000 04:35:36
Try some PB blaster. that stuff is wonderful!!!
Joe M
11-23-2000 15:11:08
When I replaced mine, I was in the same boat !
Since You have a replacement one, I would saw off the old one right at the fitting behind the guage
and then, either use an easyout , or use a good small punch to roll up the threaded part a little, then you should be able to twist it out with a good pair of needle nose pliers.Unless your radiator is junk, it is a lot stronger than you think, but caution is the best tool !
