Draft on wd
greg in ne.
11-22-2000 20:37:48
can any of you guys give me a few pointers on the draft control on my wd. Dont know zip about it or how it should hook up or even the advantage of it for that matter. I did hook a line in to the hydrulic control block so i could run the cyl. on my disk. Appreciate any info. Thanks
L.Hud
11-23-2000 17:06:21
 Re: draft on wd in reply to greg in ne., 11-22-2000 20:37:48
For the draft to work the screw on the control block should be all the way out. This seperated the two plates. The screw on the side of the pump should be out also. This lets the spring in the pump work. The linkage on the drawbar that goes to the pump should be properly ajusted. I don't remember the exact measurement but 1/4 to 1/8 of and inch seems correct.
