Where can we put a temp gauge on wc
Tom Bunnell
11-22-2000 15:50:24
our 34 wc has no temp gauge, on left side of motor a few inches to the front of tractor by the carb is a removable threaded plug. the parts store told my dad, not being 12 volt, (IS MAGNITO) that nothing will work, does anybody have solution, thanks
Johnny
11-23-2000 07:56:30
 Re: where can we put a temp gauge on wc in reply to Tom Bunnell, 11-22-2000 15:50:24
Tom, Norm has the answer, The temp gauge mounts on top of the radiator through the hood, there should be a threaded hole on top near the place where the radiator hose comes in, I just put a new one on my WC, you should be able to find one from one of the parts suppliers on this site, Got mine from Restoration Supply Co. 1-800-809-9156 part no.AC064 , Johnny
BamaDee
11-22-2000 18:31:37
Ithink you are describing the drain plug for the block (about 1/2 inch pipe thread?) You may want to try looking for a capulary tube type thermometer used on hot water type heating systems and small boilers. The operating temp on my WC's is around 170-200 deg.F .The trick is to find a thermometer with a small sensing bulb that's not too long and operates in this range. The good news is, they do not need any electrical power . I don't have my catologs here to give you a part number,but a good plumbing supply house will help you. Good luck Dee
