Wiring harness replacement question for 1942 C
Fred NC
11-21-2000 16:26:29
42C wiring has not be operable in at least 25 years. I have replaced the harness per wiring diagram. ?#1) The cut-out relay attached to generator case shows connected to ammeter,but my generator has a terminal A with a old wire attached, does this attach to the other cutout terminal, My orginal manual shows it does but the wiring diagram does not show it at all. ?2)Diagram shows green lt wire attaching to junction between the two head lts. Do I have to furnish the head lt wiring myself? I don't even have my ft lts yet.?#3)My lt switch and magneto ground switch are completely rusted out and gone. What is the easiest way to replace them?Obviously I'm not a electrican and can use all the help I can get!!
Thomas
11-22-2000 19:57:17
 Re: Wiring harness replacement question for 1942 C in reply to Fred NC, 11-21-2000 16:26:29
The short wire from (A) terminal on generator
connect to cut out. The hot wire from ammeter
connect to( Bat)side of cut out.As for the lights
one wire from light switch to upper part of radiator left side above generator.It should be
thread stud one wire for each head light plus the hot wire from switch.I can't help with magneto
mine AC all have dis.
