WCwater pump
BamaDee
11-18-2000 12:08:23
How is the shaft removed from the pump body? I took the fan collar off, and the rear impeller plate off, also the clip ring in front of the bearing.The shaft will rotate , but won't slide out of pump body. What have I overlooked? TNX BamaDee
allis_wc
11-18-2000 20:57:47
 Re: WCwater pump in reply to BamaDee, 11-18-2000 12:08:23
the pump shaft is pressed on. you will need a press to remove the shaft from the body. I never had any luck at rebuilding the water pump on any engine.
