Allis WC WD engine overhaul
isaac
11-16-2000 19:24:35
I am looking for a web site that gives you information on how to overhaul WC & WD engines to realy give them the horse-power to pull.
L.Hud
11-19-2000 15:13:16
 Re: Allis WC WD engine overhaul in reply to isaac, 11-16-2000 19:24:35
The easiest hp is to use the 45 crank and the WD or WC pistons. The rods are the same in them all except the shimming of the older ones. This will up the compression considerable.The overbore kits of one eighth is prefered.
LB
11-16-2000 19:34:45
I think what most guys do is put a crankshaft,sleeves and pistons from a WD45 in to up the HP. That seems like the cheapest. That way you get it bored and stroked. A more expensive way is to take a WD45 crank and get it stroked by a machine shop for you for added cubic inches. I'm not real familiar with how that all works but have been thinking about trying it with a D17 engine I have. But I'm frugal by nature.
Tom
11-17-2000 18:53:38
 Re: Re: Allis WC WD engine overhaul in reply to LB, 11-16-2000 19:34:45
What about using a D-17 engine, they had more power than a 45, or using D-17 parts, pistions, liners, cam , etc to rebuild a 45 engine. Or putting all of this stuff plus a 45 crank in a WD or WC? Does anyone know how much of these ideas will fit? It would seem that you could bring a WC up to the power level of a D-17 by swapping the newer parts into the older block.
Mike B
11-18-2000 20:44:45
 Re: Re: Re: Allis WC WD engine overhaul in reply to Tom, 11-17-2000 18:53:38
It will all fit but if your going to stroke it use a wc or wd or 45 block you can stroke it farther than a D-17 block. You can also use a gleaner combine engine for more horse power than a D-17. Hope this helps
LB
11-19-2000 07:48:45
 Re: Re: Re: Re: Allis WC WD engine overhaul in reply to Mike B, 11-18-2000 20:44:45
Why can you stroke WC,WD and WD45 blocks further than a D17 block? not arguing just asking.
Tom
11-19-2000 15:04:17
 Re: Re: Re: Re: Re: Allis WC WD engine overhaul in reply to LB, 11-19-2000 07:48:45
I was wondering the same thing myself.
Mike B
11-19-2000 20:50:32
 Re: Re: Re: Re: Re: Re: Allis WC WD engine overhaul in reply to Tom, 11-19-2000 15:04:17
If you compare the two the d-17 or gleaner block is shaped differently than the others so there is less room inside for the crank to swing
