WD Crank
Dan
11-13-2000 08:25:44
Is storage for WD crank on right or left fender. Looks like holes are correct for it on left side.
Pat
11-13-2000 10:15:06
 Re: WD Crank in reply to Dan, 11-13-2000 08:25:44
Dan, on my 1953 WD, the crank is on the right fender, mounted in what appears to be original brackets; however, it appears to me the brackets could also be positioned on the left side in the same bolt holes as on the right.
Dan
11-13-2000 14:18:26
 Re: Re: WD Crank in reply to Pat, 11-13-2000 10:15:06
Thanks, Pat. I thought I had seen them on the right side, but one of the holes I had assumed is used to bolt on the holders is in the heavy fender plate but is not drilled through the fender. Perhaps one of the bolts used to attach the fender also holds the front crank bracket too? Does the round bracket that the crank hand goes down through go in rear or front? Also, this is a '48 WD. I think our old '47 WC had the crank on the left fender.
Gary(Ont.)
11-13-2000 15:46:20
 Re: Re: Re: WD Crank in reply to Dan, 11-13-2000 14:18:26
Standing behind the tractor (WD and WD45 )the tool box is mounted to the left fender and crank supports are mounted to right hand fender.
According to picture in manual, it appears the round bracket is at the front, and L bracket goes at the rear.Gary
Pat
11-14-2000 13:35:35
 Re: Re: Re: Re: WD Crank in reply to Gary(Ont.), 11-13-2000 15:46:20
Dan, Gary is right, and the business end of the crank itself sits in the L bracket.
Pat
Dan
11-14-2000 15:53:14
 Re: Re: Re: Re: Re: WD Crank in reply to Pat, 11-14-2000 13:35:35
Now, the real test: can you describe to me which bolts (for sure) hold the crank holders? I think I have figured it out, but want to be sure. Thanks in advance.
