Weight for wd
greg
11-12-2000 17:53:49
I have a wd that i put rims on from a massy combine (also same bolt pattern as #5 john deere combine ). The tire size is 16.9 on a 26 inch rim. I need some weight and i dont like calcium Dose any one have any ideas on what kind of weight a guy can put on. I thought of making cement weights but once its in the rim it would be hard to put back on the tractor. Any ideas would be appreciated. Thanks Greg from Neb.
T Seifert
11-12-2000 18:57:31
 Re: weight for wd in reply to greg, 11-12-2000 17:53:49
Save your old antifreeze and fill tires. It does not corode
Gary
11-13-2000 15:50:00
 Re: Re: weight for wd in reply to T Seifert, 11-12-2000 18:57:31
I have heard of using windshield washer antifreeze, it is cheap, doesn't freeze, doesn't corrode, and readily available.
Tom
11-15-2000 18:02:44
 Re: Re: Re: weight for wd in reply to Gary, 11-13-2000 15:50:00
Old antifreeze works. have had it in a B for 10-15 yrs. Have all your friends save it.
