B Model Hand Crank
Tony Reed
12-09-1998 17:53:00
Can anyone tell me where the hand crank mounted on a 1944 "B" model when not in use?
Brian P.
12-27-1998 07:02:38
 Re: B Model Hand Crank in reply to Tony Reed, 12-09-1998 17:53:00
Directly underneath the gas tank, facing the driver is a hole in a formed piece of sheet metal. The crank is stored in there. It goes in to the first bend in the crank, thereby leaving the handle exposed. It sets alongside the steering column, when in place. As you sit in the seat, you will be looking at the handle end of the crank.
Brian P.
12-27-1998 06:57:50
There is a formed, sheet metal enclosure that wraps arount under the steering column. The crank is stored in there by simply inserting it into the hole in that enclosure. It goes in as far as the first bend in the crank, thereby leaving the crank handle exposed. The area I am talking about is right under the gas tank. As you sit in the seat, you will be looking right at the handle end of the crank.
