WD hand clutch
Dan M.
11-06-2000 17:18:04
On my WD there is a brass bushing that moves the
hand clutch in and out. My question is how do I
replace it without splitting the tractor. I got
the old one off, but can't get the new one back
on. Can't get the ears to go in the forks.
Thanks
Gary(Ont.)
11-08-2000 14:30:25
 Re: WD hand clutch in reply to Dan M., 11-06-2000 17:18:04
Dan
I had to replace this brass collar on my 1949 WD last year. Rather than split the tractor , I removed the R/H side rail frame , then I removed the set screw that secures the fork to the shifter shaft.Then I pulled the shifter shaft out of the housing .This freed up the fork so that brass shifter collar and shifter could be lined up. Worked for me.
Dan
11-08-2000 15:57:46
 Re: Re: WD hand clutch in reply to Gary(Ont.), 11-08-2000 14:30:25
Gary,
Do I have to block up the side or does the rail
just come off.
Thanks for the info.
Dan
Gary(Ont)
11-09-2000 02:46:55
 Re: Re: Re: WD hand clutch in reply to Dan, 11-08-2000 15:57:46
Dan
You need to support the front end of the tractor since the front steering housing support is only bolted to the two side rails.Gary
