WD-45 question
Chris
11-04-2000 20:32:19
Hi all. I'm a Farmall guy who strolled over to ask a question. Today, I drove a WD-45 to pick up some dumped grain. The tractor was already idling in 2nd gear and the owner told me to push in the foot clutch, pull back on the hand clutch, and let out the foot clutch. Why so complicated? I've been trying to figure out why the hand clutch is necessary. How does it operate differentl from a foot clutch? Just curious.
Thanks, Chris
By the way, I thought the tractor was a joy to drive.
c tucker
11-05-2000 04:52:54
 Re: WD-45 question in reply to Chris, 11-04-2000 20:32:19
Chris, The hand clutch is a transmision clutch,used
to stop the tractor while keeping the PTO and hydraulic pump running.To operate the clutches the way you did puts the wear or initial load on the engine clutch. ct
Chris
11-05-2000 06:18:13
 Re: Re: WD-45 question in reply to c tucker, 11-05-2000 04:52:54
I didn't think that was the proper way to use the clutches, but it wasn't my tractor. Thanks, Chris
Tom
11-05-2000 12:54:14
 Re: Re: Re: WD-45 question in reply to Chris, 11-05-2000 06:18:13
There is no real proper way to use the clutches. Either will stop or start the tractor. The hand clutch is a multi-disc that runs in the transmission oil. It can take a good amount of abuse with out much wear. The engine clutch or foot clutch is a more typical clutch for a tractor, a single plate dry clutch. Using it will also stop the PTO, and hydraulic pump, sometimes this is usefull and sometimes it doesn't matter, and sometimes you want to stop the tractor and keep the power flow to the PTO uninteruped, then the hand clutch comes in, it is after the PTO and hydraulic systems. It only stops power to the transmission. If the oil is cold and the hand clutch has been left disengauged it can seem not release due to thick cold oil between the plates, put the tractor in gear with the foot clutch and go on about your work, when you need the hand clutch it will now work as the oil has been squished out from the plates and is probably warmer. When I was a kid working on a farm in the mid 60s the AC dealer told us if the hand clutch was prone to slip under heavy load in the winter, that it would be OK to run straight 20 weight engine oil in the transmission and rear end instead of the much thicker 90 weight gear oil. I saw this tractor run and function for thousands of hours with 20 weight in the transmission and rear end summer and winter, in New England.
