Pto gear box gaskets
Charles Zook
11-03-2000 06:12:01
Wd allis pto gear box, and i need the paper gaskets, along with the metal spacers that are installed on the front side of the casing. Had to remove to take out stub shaft assembly. Thank You in advance. D. Zook
Mr. Rogers
11-03-2000 17:56:51
 Re: pto gear box gaskets in reply to Charles Zook, 11-03-2000 06:12:01
I can't help you with your gaskets, but, do you know where I can get information about the PTO for a '48-'53 AC tractor? Are they easy to repair? Are the PTO's reliable once repaired?
Joe M
11-04-2000 10:37:50
 Re: Re: pto gear box gaskets in reply to Mr. Rogers, 11-03-2000 17:56:51
Mr. Rogers, What model AC are you dealing with
Mr. Rogers
11-04-2000 17:34:57
 Re: Re: Re: pto gear box gaskets in reply to Joe M, 11-04-2000 10:37:50
My question should have been: How do you engage a PTO for a WD-45?
If you can help, please post a reply.
joe m
11-05-2000 20:07:51
 Re: Re: Re: Re: pto gear box gaskets in reply to Mr. Rogers, 11-04-2000 17:34:57
the pto should be controlled by a lever by your right foot on the inside of the frame rail. Pull for pto, push for off. You should be able to see where it joins the pto drop case under the trans.
