Draft Control on CA
John
11-02-2000 12:55:34
Does the CA model have a lever to switch from draft control to position control? If so, where is it supposed to be. Also, where can I find a picture of the snap hitch and a description of how it is supposed to work. I looked at a tractor today and the owner said a pivot pin had to be inserted to hold the plow tounge in the hitch. Any help would be appreciated.
c tucker
11-03-2000 15:54:41
 Re: Draft Control on CA in reply to John, 11-02-2000 12:55:34
If you have to put a pin in the plow hitch you don't have a snap couple hitch. I have a 1951
CA without the snap couple,I don't know if it
was an available optin in 1951.I belive you can
add a snap couple hitch.
Ted Seifert
11-02-2000 17:32:31
Yes. Lower implement first. Then turn lower thumb screw in the small arm into body stoping lever from moving. Then turn top horizontal thumb screw out of body thereby locking the two plates together. Turm screw on front side of pump out as far as possible. It is a little hard to visualize without the pictures in the manual. If you e-mail a fax number I will fax that part of the manual. If no fax number e-mail your address and I will mail you that section of the manual at no charge.
