WD45
Hydraulic pump always pumping
Todd
11-01-2000 17:54:56
We have a WD45 and the hydraulics will not
lower / release anymore? When you pull the
lever on steering column down to lower / release
hydraulics it does nothing...u can still hear
the pump, pumping away. We traced the level
mechanism to the place where it goes into the
hydraulic pump and it appears to be working
properly. Please help?
Do we need to pull the hydraulic pump?
Is this likely serious?
Thanks, Todd
mark/indiana
11-03-2000 10:05:18
 Re: WD45 - Hydraulic pump always pumping in reply to Todd, 11-01-2000 17:54:56
I HAVE FLUSHED WITH DIESEL FUEL AND AFTER A SOAK TIME... RAN THE PUMP BRIEFLY TO FREE IT UP...I AM SURE IT IS DIRT OR VARNISH..LET IT DRAIN WELL BEFORE PUTTING IN HYD. FLUID..MARK
D-17 Dave
11-01-2000 18:41:35
Check the hitch spring abiliaty to move freely. If it sticks, this could cause the linkage to appear to be working but be hanging the draft in the raise position. My two cents worth, good luck.
Craig
11-01-2000 20:49:52
 Re: Re: WD45 - Hydraulic pump always pumping in reply to D-17 Dave, 11-01-2000 18:41:35
My dad who works for Allis tells me the spools inside your pump are stuck. You need to turn the thumb screw in front of the pump in so it cancels the pump out. Then turn it back out, by hand, all the way. Try this a few times. If this does not work the pump my have to be removed and cleaned. Hope this helps. -=Craig=-
