Allis Chalmers D15 Hydrylic Oil Problem PLEASE HELP
Matt Compton
10-30-2000 13:00:19
Hi I own a 63 Allis D15 the problem is that the hydrylic oil that u put in next to the pulley, is somehow getting into the transmision, after a few hours of work the dipstick by the pulley shows nothing and the one by the gearshift is overfull how do i solve this problem
GeneD14
11-02-2000 07:40:27
 Re: Allis Chalmers D15 Hydrylic Oil Problem PLEASE HELP in reply to Matt Compton, 10-30-2000 13:00:19
There are also seals that separate the hydraulic compartment from the transmission that wear with age and allow this to happen. Narrow down your problem by correcting the fluid levels, then run the tractor for 15 minutes or so without using the hydraulics at all. If the fluid levels don't change it's the lift cylinder, if the fluid levels change it's the seals between the hydraulic and transmission compartments. Good Luck!
Jeff
10-30-2000 17:02:28
Lift cylinder is in the trans the cylinder is either in need of seals or the lift cylinder hose is leaking.
