WD45 Sudden Clutch Problem
Need Help
Jerry
10-28-2000 15:53:22
I was mowing corn stalks on a hillside field and my WD45 started to sputter and then just quit. (spark plugs fouled) I drained the battery trying to get it going without success so I used the hill to my advantage. With the hand clutch engaged, I pressed in the foot clutch, put it in fourth gear and "roll started" it. It ran rough to the barn (down hill the whole way). Today I changed the plugs and she started right up, but when I went to put it in gear it was like I didn't even have the clutch pressed in???? I had to turn it off to put it in gear - then I could use the hand clutch to start and stop. The linkage works mechanically - what could have happened??? I'm an old two banger John Deere Guy so I don't have a clue. Thanks for any assistance!
Jerry
10-29-2000 15:30:19
 Re: WD45 Sudden Clutch Problem - Need Help in reply to Jerry, 10-28-2000 15:53:22
Thanks for the help. I looked inside where you said and found one of the pins had fallen out. I reinstalled the pin and verified proper operation of the clutch. It smelled a little burnt inside but everything functions properly now. Back to mowing....THANKS AGAIN!
Sandy Lake Implement
10-28-2000 18:07:02
Take a look up through the clutch housing inspection hole after removing the cover. Sounds
like you have had a failure of a clutch finger pivot pin or the ends of the fingers have
collapsed. I can't think there is any connection
to your running problem. Good luck, Bill
