Oil passage in B, C , CA Blocks
Dick L
10-26-2000 12:20:13
third party image
In answer to an earlyer question.
You can see where the oil flows from the oil filter base out the front of the block behind the cam gear by looking through the governer gear bearing. If you have over size tires on the front or the tractor parked with the front up on a incline, the oil can run over the filter base with the filter off.
I should have had the block level for the picture, when it is level the hole in the filted base is only slightly above the large port in the front above the cam bearing.
