Can I add hydraulics 3 pt. to C?
Dave
10-24-2000 13:35:53
I have a mid-forties C with a 6' Woods belly mower. My 85 yr. old dad still mows with it but has a tough time lifting the mower with the hand lift lever. Can I add hydraulic lift? If so, how difficult and expensive is it to do? Also, is it feasible to then add a 3 pt. hitch somehow? The tractor needs some reconditioning and I want to know if it's worth it as I want to do more than just pull something with the standard drawbar. Thanks.
Dave
10-25-2000 05:43:23
 Re: Re: Can I add hydraulics 3 pt. to C? in reply to Dick L, 10-24-2000 19:31:33
Thanks, but I don't have any hydraulics to lift anything right now . . . including the cultivators. There is no hyd. system. Was it an option?
Dick L
10-25-2000 13:26:07
 Re: Re: Re: Can I add hydraulics 3 pt. to C? in reply to Dave, 10-25-2000 05:43:23
third party image
Yes it was an option. The belt pully, power take off, and hydraulics are all in one unit and bolts on under the seat. Just remove the cover and it bolts on in the same holes. You will need to make sure that you get the roller bearing that goes on the end of the transmission shaft. About 125.00 at an Allis scrap yard.
