C Final Drive Oil
Leo
10-21-2000 12:19:33
Thanks to Bill for answering my question on C gear box oil. I forgot to ask about the final drives.
The lower final drive cases both have what looks like oil level check plugs on them. Do the final drives get their oil from the upper gear boxes or do they use their own oil supply? If they have their own oil supply what grade of oil does the final drive use?
ELDON in MN
10-22-2000 18:21:14
 Re: C Final Drive Oil in reply to Leo, 10-21-2000 12:19:33
I use an oil pump with a plastic hose on the end stuck thru the oil plug to suck the oil out.
Brian G.
10-22-2000 05:39:30
Each final drive pan holds 1-1/2 pints. Fill to the plugs. To drain them, you must remove pans.
Dick L
10-21-2000 19:20:03
The book calls for SAE 140 above 32^ and SAE 90 below. I just use SAE 90 year around.
