Hard to start D19D
Bill
10-19-2000 21:20:12
This tractor will start right up when warmed up or hot, but below 60 degrees it will not go unless heated. I put on a engine coolant heater that helps but you still have to crank it over a long time before it takes off. Has fresh overhaul on it. Could pump timing be off? Or any ideas?
Jeff
10-20-2000 01:44:27
 Re: Hard to start D19D in reply to Bill, 10-19-2000 21:20:12
That is the nature of the beast. Some start better then others but when it cools off they need starting fluid or must be heated. Our D-17D and D-19D are the same way. Those old deisels don`t start to good
