wd-45 fuel injector replacement,
Kevin
10-17-2000 20:59:21
I am in the process of removing the fuel injectors from the engine so I can soak the pistons with wd-40 to free them up. Any suggestions?
Bud Sorden
10-18-2000 20:27:22
 Re: wd-45 fuel injector replacement, in reply to Kevin, 10-17-2000 20:59:21
Kevin
I assume since you are removing the injectors it is an Allis or Buda diesel. My experience with them is to remove the head and use penetrating oil. Is much simpler than messing with the return and pressure lines.
MATT MCGOUGH
02-02-2001 15:43:48
 Re: Re: wd-45 fuel injector replacement, in reply to Bud Sorden, 10-18-2000 20:27:22
LOOKING FOR AN INJECTOR PUMP SEAL KIT OR WHOLE PUMP FOR BUDA DEISEL 6 CYL. ANYONE KNOW WHERE TO FIND PARTS?
MATT MCGOUGH
02-02-2001 15:43:13
