AC WD rear end howel
Ted Seifert
10-04-2000 13:44:18
I have a 1950 WD that has a terrible howel in the rear end ,right side I think, it has been ther for many years. It is especially bad at low speeds under load. Where do I start looking? Is this common? What is the most likely cause? All help is greatly appreciated.
Brian G.
10-05-2000 06:47:36
 Re: AC WD rear end howel in reply to Ted Seifert, 10-04-2000 13:44:18
Dave is referring to the "final drive" gears and he is right, they do tend to howl. I would definitely pull the pan and drain it. At the same time, check the condition of the gears and the axle bearings. I know a guy who had a bad rear axle bearing in his WD and let it go until it wore the housing to the point where it will no longer hold a bearing.
Sandy Lake Implement
10-04-2000 19:42:40
Your howl is "nature of the beast" That is one
reason the 45s had helical cut gears as opposed
to the straight cut ones in the WD
Dave Kolby
10-04-2000 14:37:04
Well they all howl a lot, these are straight cut gears but if one side is louder you probably need oil in there. There is a pipe plug on the side of the rear wheel gear housing on the tractor side. The grease should be up to that hole, fill with (if I remember right) 90W gear oil. If you have water in there you have to remove the pan at the bottom, below this hole and clean and refill, need a new gasket too.
Dave
