C Front end wobble, How do I fix
Bill From WI
09-27-2000 09:12:20
I HAVE A "C" WITH A 6' PLOW ON THE FRONT AND WHEN I TRAVEL DOWN THE ROAD I HAVE A WOBBLE IN THE FRONT END (NARROW). WHAT IS WRONG AND HOW DO I FIX IT. CAN CARRYING THAT MUCH WEIGHT IN FRONT CAUSE THIS? IT DOES NOT HAPPEN ALL THE TIME.
Dick L
09-27-2000 13:44:04
 Re: C Front end wobble, How do I fix in reply to Bill From WI, 09-27-2000 09:12:20
It is caused from worn parts. You need to watch and see what all moves that should not be moving, from the front wheels back to the stearing wheel. If you have slop in the stearing wheel with out moving the stearing arms you might be able to help it by tightening the set screw on the right side of the stearing box under the gas tank. If that don't help you will have start taking things apart after you locate where the movement is comeing from. If it has had a lot of weight on the front end for an extended time it could have the tip wore down on the cross shaft in the stearing box. This tip can be replaced or you can buy the complete cross shaft. There can be several other things that could be a problem.
The C that I pull has the same problem and I lowered the air pressure in one tire untill I get too repairing the stearing box, but I don't have any extra weight on the front.
