WD hydraulic ?
Farmboy
09-26-2000 18:50:18
I just put a loader on my WD and would like to use the three point to hold a blade for added weight on the back. What kind of valve can I put in the hydraulic line that will withstand the high pressure of AC's. I put a ball valve in and tried the lift with the valve closed just to test and it ruined the ball valve. Would a tapered pin brass valve work?
Thanks
Ron
09-26-2000 23:01:20
 Re: WD hydraulic ? in reply to Farmboy, 09-26-2000 18:50:18
Farmboy parker makes a F series flow control valve rated at 5000 psi part no.600s you can get it from northern tools for $24.95
