MOTOR ON C
WILL
09-25-2000 07:01:48
I WOULD LIKE SOME INFO ON HOW I CAN GET SOME MORE POWER OUT OF THE C MOTOR FOR PULLING.HAS ANY ONE BUILT ONE. THANKS FOR ANY HELP. WILL
Phil auten (TX)
09-25-2000 07:54:02
 Re: MOTOR ON C in reply to WILL, 09-25-2000 07:01:48
Will,
Start with oversize pistons/sleeves. Then shave the head for more compression. Next work on the governor to get a little more rpm. Next would be cam regrind and head porting/polishing. Also, a larger carb, maybe one from a WC or WD, but not until the other things are done. Basically the same things you do to an automobile engine for more power.
Phil
brian
10-04-2000 21:35:12
 Re: Re: MOTOR ON C in reply to Phil auten (TX), 09-25-2000 07:54:02
WILL,
MY DAD AND I HAVE JUST FINISHED BUILDING A MOTOR FOR A C. WE SPENT AROUND $2,500 ON THE MOTOR ALONE. EVERYTHING PHIL SAID IS WHAT WE HAVE DONE, EXCEPT WE ALSO BOUGHT A D-10 CRANKSHAFT, HAD IT GROUND TO FIT THE BLOCK. I DON'T REMEMBER HOW MUCH MORE STROKE IT GAVE IT, BUT IT WAS ALOT.
IT WILL GIVE QUITE A BIT MORE HORSEPOWER.
BRIAN
