CA clutch
Don E. Foster
09-21-2000 14:48:30
I haven't figured out how to adjust the CA clutch. It seems to have way too much stroke before it releases. No way to shortenthe clutch rod from the pedal..... .
Thanks.
Al
09-22-2000 05:14:46
 Re: CA clutch in reply to Don E. Foster, 09-21-2000 14:48:30
Did you set up the fingers thur the bottom hole on the pressure plate and the throwout bearing? Al.
Dick L
09-21-2000 19:54:16
You can take the rod out of the clutch pedal and the other end is threaded. Turn it counter clock ways, but there is not very many threads. Still might be enough to help.
