B C rusted brake pin removal
Dick L
09-20-2000 06:56:24
This picture shows a final drive casting that does not have the brake pins showing on the inside. When they are rusted in you can drill small holes through the casting as close to the center of the pins as you can get. In the next picture you can see these holes.
NEXT PICTURE
09-20-2000 07:10:04
 Re: B C rusted brake pin removal in reply to Dick L, 09-20-2000 06:56:24
third party image
This picture shows the holes and then you can drive the pins out. After the pins are out you can drill from the other side by hand at the pin size and have the hole on center and as some came from the factory. That picture did not come out and will have to be retaken.
FIRST PICTURE LAST
09-20-2000 08:15:59
 Re: Re: B C rusted brake pin removal in reply to NEXT PICTURE, 09-20-2000 07:10:04
third party image
I goofed
