WD gnerator-how to test??
Bob B
09-16-2000 19:07:03
My WD generator doesn't charge in the + anymore even on high charge. How do I test the gen and cutout relay? I assume it has to be one of these that is the problem???? (6 volt system) Thanks
Brian
09-17-2000 11:11:38
 Re: WD gnerator-how to test?? in reply to Bob B, 09-16-2000 19:07:03
You can test the gen on the tractor by pulling the belt off and with a hot wire, touch it to the A post. (the one hooked to the cutout) If the generator is good, it will spin like a motor. With the engine running at full speed, jump across the cutout with a heavy piece of wire. If it charges, the cutout is bad. Hope this helps, Brian.
Glenn
09-16-2000 20:48:10
If you take it to a good automotive electrical shop, I'll bet they'd be willing to test it for free - and it wouldn't take more than a few minutes.
