Front mounted hydraulic pump on Allis Chalmers D-17
Paul
09-09-2000 08:29:44
The deer hunting club I belong to has an Allis Chalmers D-17 tractor with a hydraulic pump mounted on the front that furnishes the pressure to raise and lower the wheels on the disc harrow. We cracked the housing on the pump and would like to purchase a replacement. Can anyone tell me the capacity and pressure output of these pumps? U. S. Patent number on the pump is 2809592 if that's any help.
Rick Sharp
10-11-2003 12:21:17
 Re: Front mounted hydraulic pump on Allis Chalmers in reply to Paul, 09-09-2000 08:29:44
I have the same pump on my John Deere 2010 industrial loader and cracked the case on it also. some of the information you need to know is the shaft dials to .872'', is 1.5'' long, with 13 splines, mounting bolts are 5 3/4'' to center with .541'' mounting holes. I'm going to try to match it, tried welding with my aluminum welder but couldn't get adequate penetration, might also take mine to my machinist if I can't find a match. It is made by Cessna, part number 2010090. Not sure if they are still in business, not finding them on the web. Good luck.
Linda Jo Landau
11-17-2005 17:48:52
 Re: Re: Front mounted hydraulic pump on Allis Chal in reply to Rick Sharp, 10-11-2003 12:21:17
I have the same pump, did you ever find a replacement for yours? We are having difficulty finding one. We have it on a Case 444 for a work horse front end loader. Thanks for any info you might have.
Phil Auten (TX)
09-11-2000 04:29:27
 Re: Front mounted hydraulic pump on Allis Chalmers D-17 in reply to Paul, 09-09-2000 08:29:44
Paul,
This sounds like an aftermarket pump. See if you can get more info on it, like manufacturer (it might be a pump from M&W Gear). I don't have anything on that number.
Phil
