CA clutch adj.
David W
09-08-2000 02:42:50
My clutch rod doesn't seem long enough to yoke.
I replace clutch disc plate and throw out bearing. Now I have to turn rod all the way out but one thread in order for clutch to engage. Did I miss something or do I need to somehow lenghten r
Dick L
09-08-2000 09:37:19
 Re: CA clutch adj. in reply to David W, 09-08-2000 02:42:50
I have seen where the arms on the pressure plate would be worn away from the through bearing seizing up and spinning. Other than not getting the bearing casting in the frame correctly I can't see another reason.
