Tractor tires
buktu in Tenn
09-07-2000 06:10:09
On 8-18-00 I posted a message in which I mentioned narrow tires pulled harder. I was suprised to have receved no responce. I found where I had read this message and I quote.
"If all you want to do is pull harder, narrow tractor tires are better than wide tires. That's the word from the National Tractor Test Laboratory at the University of Nebraska. Three-year-old test results there showed that 18-inch radial tractor tires provided more pulling power than either wide bias or wide radial tires. Of course, if you want less soil compaction and a better ride, wide is better.
Taken from the Progressive Farmer August 2000 issue, page 66.
Aaron
09-07-2000 17:39:46
 Re: tractor tires in reply to buktu in Tenn, 09-07-2000 06:10:09
That would be refering to pulling, as in in the field, not hooked to a sled. With something like pulling, where you almost always run out of power before you spin the wheels, especially in antiqes classes, wider is better to assure that you do infact, run out of power first. No one likes to spin out with lots of power left. Now, in the field, efficiency and economy are the considerations, and there, wider might not be better.
Aaron
Dick L
09-07-2000 06:47:16
I will respond, I do not disagree with the test,but. I have a tractor that I pull that has narrow tires and on some tracks they work best and I do well, but on different track conditions they wont do squat. I have found that for pulling in the antique/ classic pulls the wider tires will get you more wins than the narrow tires. The same track is never the same from one pull to the next. It is a guessing game at best.
