Wide front for Model C
Mike Weinrich
09-06-2000 10:34:43
Does anyone know if they made a wide front for the C or if a wide front from a B will fit on a C.
Phil Auten (TX)
09-06-2000 10:38:13
 Re: wide front for Model C in reply to Mike Weinrich, 09-06-2000 10:34:43
Mike,
The ADJUSTABLE wide front axle was the same on the B and C. It's a square tube type. Pretty easily recognized on a B or C.
Phil
Bob Wild
09-07-2000 12:55:54
 Re: Re: wide front for Model C in reply to Phil Auten (TX), 09-06-2000 10:38:13
While the frames for the wide fronts of a B and C are similar and a B wide front will fit on a C the steering arms are different and you will have to change out the steering box as well to use a B front end on a C.
huck
09-10-2000 06:35:29
 Re: Re: Re: wide front for Model C in reply to Bob Wild, 09-07-2000 12:55:54
the AWFE on the B is totally different from that of the C.the B doesnt utilize a steering box it is controlled by linkage,whereas the C has a gearbox on the front end.they also differ at the rear steering box with the B steering arm coming out at 6 o'clock while the C connects at 12o'clock with distinctively different arms.
