Hd3 steering clutches
SKIP
09-05-2000 11:00:17
Can someone please provide me the info on how to adjust & replace the steering clutches in a 60s model HD3 dozer.It would be very much appreciated
thanks
glenn
09-07-2000 21:17:45
 Re: hd3 steering clutches in reply to SKIP, 09-05-2000 11:00:17
If you need to replace the friction material you should get a manual. It is not a hard job but it is very time consuming.I have done both of mine this summer and i would have been lost without a manual.Adjusting them is not to difficult,go to the sproket and look above the track, there is a larg nut on a threaded shaft. the shaft has a hole in it,so that you can insert a screwdriver to hold it in place. back the nut off several turns, then turn the shaft
inward. this will move the throw out bearing closer to the preshure plate and give you more throw on the lever.good luck
