AC tractor (what is it)
frank fowler
09-04-2000 16:13:48
I found an AC tractor that I would like to restore
but I figure out what it is, It looks like a WD,
wide front(I think it is factor),# on rear housing
looks like c_0531, #on engine block w174988k, it has a cable lift on back,has a hyd.cylinder that moves cable,has a victor hyd.power packon pull shaft. any help would app. thanks
Phil Auten (TX)
09-05-2000 04:33:29
 Re: AC tractor (what is it) in reply to frank fowler, 09-04-2000 16:13:48
Frank,
It's probably a styled WC. Was the S/N on a raised spot in the center of the rear axle? If so, that pretty much makes it a WC. Scrape or wire brush the spot thoroughly to see if you find:
TRACTOR NO
WCN0531
under the accumulated paint and crud (the N represents another number).
Then check the serial number reference under the Research & Info heading on the left side of this page. You will probably need to scroll down a bit to see it.
Let us know what you find,
Phil
