Allis G oil pan removal
Jim
09-03-2000 18:15:08
Can anyone tell me if there's a way to get to the three bolts on the flywheel end of the oil pan on the "G"? There's not much room between the pan and the clutch housing, and I can't get my 1/2 inch socket and universal joint in there. I can't believe you'd have to pull the engine just to get the pan off! Tell me not so! Thanks, Jim. P.S. If the engine's got to come off, do I need to mess with the pilot bearing, or is that only the case if you separate the tractor at the next point, ahead of the clutch?
