Model C serial #
Brett Carpenter
09-01-2000 05:53:44
Where is the serial # located on the model C at. I've been told it's by the shifter but I'm not sure. Thanks, Brett
Scupper
09-01-2000 07:15:56
 Re: Model C serial # in reply to Brett Carpenter, 09-01-2000 05:53:44
Brett, it's stamped in the casing just forward of the shift assembly. It may take a bit of wire brushing to be able to read it. In my case, I also had to use a magnifying glass to figure out the numbers, it was so eaten out with rust. You're serial number will begin with a "C".
Hope this helps.
PS also
09-01-2000 07:20:23
 Re: Re: Model C serial # in reply to Scupper, 09-01-2000 07:15:56
Check out the article at the left in Article Archives, online book for the Little AC's.
