Hand Clutch
Bill
08-30-2000 06:21:49
I have a WD model with a hand clutch, pto, two rear arm lifts, hydraulic front loader w/trip buckets (snow and dirt) and a serial # of WD803. Is this a 1949 model with added options or did they make these options back in 1949? I was told the hand clutch came out in 1951 or so. Also, what would this tractor be worth? It's in great shape with a new paint job.
Brian G.
08-30-2000 08:25:17
 Re: Hand Clutch in reply to Bill, 08-30-2000 06:21:49
It's a 1948 WD. The WD began production with the options you list and they (along with some other improvements) were continued on the WD-45. Scroll down to my earlier messages on 8/27 & 8/28, as well as my messages posted on 8/25 (page 2) for more info.
Bill to Brian G.
08-30-2000 08:56:08
 Re: Re: Hand Clutch in reply to Brian G., 08-30-2000 08:25:17
Does this mean it was probably the 803rd that rolled off the line? Also it does have an 8 volt alternator system that seems to be doing fine. Do you know relating to the coil if the + side lead of the coil goes to the side of the distributer or is it the - side of the coil that I connect to with this style polarity system? Do you off hand know what this WD roughly would be worth (it was handed down to me by a passing uncle of mine)? Thank you Brian for the reply!
Brian G.
08-31-2000 05:57:38
 Re: Re: Re: Hand Clutch in reply to Bill to Brian G., 08-30-2000 08:56:08
The Serial number of the first WD was 7. As Butch says, if your tractor is still wired "positive ground" the + terminal goes to the distributer. Prices vary across the country and condition plays a big role. If it runs well, has very good "tin",tires and rear wheels, I would say $1,000 to $1,200. If it has good original paint, no dents in gas tank, hood or grill shell and perfect rear fenders, it will be worth significantly more.
Butch(OH)
08-30-2000 09:45:59
Your WD should be positive ground. If so the + side of the coil should be wired to the distributor.
