AC B Rear Lamp Color
Jon Elsasser
08-29-2000 18:58:17
I forgot to ask when I inquired about the color of the Guide tractor lights. What is the color of the AC B rear light - orange or gloss black?
Thanks.
Brian G.
08-30-2000 08:43:39
 Re: AC B Rear Lamp Color in reply to Jon Elsasser, 08-29-2000 18:58:17
I do not believe a fender mounted tail-lite was ever factory installed on the "B". The following is quoted from the manual: "The tail light is mounted on the rear seat frame angle for use as a tail light and also for vision if equipped with a white lens." "It can be moved from the center position to either the right or left seat back bars to avoid implement interference when necessary." "When making this change, clean the mounting surface of paint so that a good ground connection can be obtained."
Dick L
08-29-2000 19:17:29
As I remember the head lights were black, the small red light on the fender was orange, and I realy am not sure about the tail light under the seat. The two that I have are orange but after 50 years that don't mean much.
Brian G.
08-30-2000 08:28:41
 Re: Re: AC B Rear Lamp Color in reply to Dick L, 08-29-2000 19:17:29
The picture in my original "B" manual shows it to be gloss black.
Dick L
08-30-2000 10:49:48
 Re: Re: Re: AC B Rear Lamp Color in reply to Brian G., 08-30-2000 08:28:41
I didn't look it up in my manual. You are probably correct on the fender light, I bought one C with the fender light and the two CA's I bought had the fender lights. The 1940 B that I am working on at this time has a hole in almost the same location as the lights that are installed on the others and it could have been drilled in the fender for any number of reasons.
Brian G.
08-31-2000 06:02:58
 Re: Re: Re: Re: AC B Rear Lamp Color in reply to Dick L, 08-30-2000 10:49:48
Yep! The "CA" manual shows a "bullit" tail-light like the ones on the WDs & WD-45s.
