Ser# ???
Dave
08-29-2000 10:06:18
I just bought a Allis Chalmers WD. The ser# on the engine is WD263458GA. I can't find it in the WD listings (is it a WD45 engine?). Any help would be appreciated.Thanks Dave.
Brian G.
08-29-2000 17:57:03
 Re: Ser# ??? in reply to Dave, 08-29-2000 10:06:18
If the engine is original to the tractor, it is a 1950 WD. WD-45 engine serial numbers were prefixed with "45" rather than "WD". The tractor serial # is located on the left rear of the differential housing between the brake spring hole and the brake adjusting bolt/locknut. All tractor serial numbers (WD or WD-45) have the "WD" prefix. This is the number you need when determining year of manufacture from the published serial number listings.
