Pto @ handclutch questions Allis CA
Paul
08-26-2000 17:24:20
I am looking to possibly purchase 1952 CA @ wond-
ering if hyd arms only operate if pto is running.
That is how this one works- doesnt seem right.
Also hole where handclutch handle is covered w/
crude sheetmetal cover. I removed cover to find
factory hole in rt axle hsng. There is what appears to be the mechanism for the clutch. Lever in hole is about flush w/hsng, has threaded hole
in it @ is spring loaded one direction. IT dont work. Nice option-poss. to repair? Poss. someone
rigged it up locked. Anybody have any info?
Dick L
08-26-2000 18:34:43
 Re: Pto @ handclutch questions Allis CA in reply to Paul, 08-26-2000 17:24:20
Good observation, and it is correct that the PTO has to be engaged for the hyd.to work, same as the B's and C's. The hand clutch lever is held on with one bolt. You would have to get a lever from a scrap yard. The clutch may have been bolted togather to keep it from sliping rather than rebuilb it.
Dan
05-16-2003 09:19:13
 Re: Re: Pto @ handclutch questions Allis CA in reply to Dick L, 08-26-2000 18:34:43
how would someone bolt the handclutch together ?I would like to do away with mine w/out an axle change if possible any info greatly appreciated
Darrell (MN)
08-26-2000 18:24:13
Paul, that is correct, the lift arms only work with the PTO engaged. As for the hand clutch, if it doesn't release, either someone has bolted it solid, or the clutch disks are froze together. The hand clucth can be repaired, but you will need to hunt the parts down. good luck, Darrell (MN)
