WD-45 identification
james rekus
08-25-2000 03:40:21
How can a person tell for sure if a tractor is a WD-45? I have been told that the WD engines have a bolt on cover on the right side of the engines and the WD-45's do not(just a solid casting). While shopping for a WD-45 I have looked at many that I think are WD's with the 45 decals.
Thanks in advance.
Jim
Brian G.
08-25-2000 05:19:28
 Re: WD-45 identification in reply to james rekus, 08-25-2000 03:40:21
Jim, If the engine has no side cover it is a WD-45 engine. But..... not infrequently you will find a WD-45 engine in a WD. Many people believe if it has the curved shifter it is a "45", but....the curved shifter was introduced on the WD with Ser.#127007. Distributer vs Magneto is not the way to go either. I believe the switch from Magneto to Distributer was made on the WD's with Ser.#136318. Besides, many early WD's were retrofitted with distributers. The tractor serial # is probably the most accurate way of identifying the model. Numbers beginning with 146607 are WD-45s. It seems that putting WD-45 decals on WD's is quite prevalent. It's a little like all the "SS" badges installed on Chevy Novas and Chevelles. When I'm "sizing-up" these tractors, my eyes go first to the shifter, then the block and finally the Ser. number.
james rekus
08-25-2000 13:23:21
 Re: Re: WD-45 identification in reply to Brian G., 08-25-2000 05:19:28
Brian: Thanks for the info. Going by the serial numbers, is it correct to assume that after WD45's began production, no more WD's were made? Jim
Brian G.
08-25-2000 15:40:01
 Re: Re: Re: WD-45 identification in reply to james rekus, 08-25-2000 13:23:21
As far as I know, yes.
