Lub. capacity
Dean in Iowa
08-24-2000 15:19:34
I have a 1952 WD Serial #127159. It has the curved shift lever so must be the "Helical cut tranny". I would like to know the total gear lub capacity of the tranny and of the differential. I want to change the lub in it and don't have a manual to get the info. I should use 80 or 90 weight gear lube correct? Also this tractor has a D-17 engine in it Serial #17-55076-14 would like to get any info I can about it. Thanks in advance for your help.
Patrick
08-26-2000 17:27:28
 Re: Lub. capacity in reply to Dean in Iowa, 08-24-2000 15:19:34
My manual says- Transmission, Differential, Clutch 17 quarts
Final drives 1 3/4 quart each
SAE 80EP
