CA final drive clutch question
Steve K
08-24-2000 14:53:03
Does this thing work as slick as the WD & WD45 hand clutch? Will it take the same abuse? I thought I saw one being used @ a tractor pull and was just curious. Thanks Steve
T Seifert
08-26-2000 10:56:36
 Re: CA final drive clutch question in reply to Steve K , 08-24-2000 14:53:03
The CA clutch servs the same purpose as the WD hand clutch. The AWD hand clutch is a wet clutch (runs in oil) whereas the CA clutch is dry , so therefore it won't take the abuse that the WD clutch will. It is said that with the CA clutch that you loose about 20% of your maximum pulling capacity.
Dick L
08-25-2000 04:42:43
They work ok, but I would guess that if they are useing it for contest pulling that the clutch has been bolted togather.
