Allice Chalmers tractor model
Pete Mills
08-23-2000 20:07:28
I've just aquired an Allice Chalmers gas engine tractor and would like to find the Model number so that I can order a manual.
I believe it is a 1949 model.
The number on the engine is "AM291620"
Where should I look for the model #.
Thanks in advance,
Pete Mills
BC Canada
Dick L
08-23-2000 20:40:49
 Re: Allice Chalmers tractor model in reply to Pete Mills, 08-23-2000 20:07:28
That is just the casting number and will not help you find the information your after. Look just in front of the gear shift lever for the tractor serial number.
If it is a 1949 it is probably a B or C because the CA started production in 1950.
The B, C, RC, and CA all would have had that casting number except for the last two numbers.
Aaron
08-24-2000 17:27:02
 Re: Re: Allice Chalmers tractor model in reply to Dick L, 08-23-2000 20:40:49
Don't forget the WD. That would have a serial number on the left rear brake housing. Can you describe this tractor some more. Frame rails, snap hitch, seat, tire sizes, etc? All can help narrow down the model.
Aaron
Philip Lambert
03-28-2002 13:37:59
 Re: Re: Re: Allice Chalmers tractor model in reply to Aaron, 08-24-2000 17:27:02
AC B please
Dick L
08-24-2000 18:41:12
The casting number referred to and shown in the center of the block was for the engine used only on the B, C, RC, and CA
Dick L picture for above post
08-25-2000 07:03:30
 Re: Re: Re: Re: Allice Chalmers tractor model in reply to Dick L, 08-24-2000 18:41:12
third party image
picture did not work with the above post
