AC-B transmission
David (Ala)
08-22-2000 14:33:28
Can anyone tell me the function of "washer spring" or "spring washer" located on trans countershaft between "locating washer" or "thrust washer" and front bearing.
Thanks, David
Dick L
08-22-2000 19:04:03
 Re: AC-B transmission in reply to David (Ala), 08-22-2000 14:33:28
The locating washer keeps the bearing in the correct position and go to far on the pinion shaft. The spring washer allows the adjusting nut to be tight and yet not cause the bearing to bind. The bearing should have some drag but not be rough when turning. A spring washer also acts somewhat as a locking device.
